Old 02-17-2011, 01:18 AM
DaneBramage DaneBramage is offline
Question re: Metal barrels
What is the best way to get a good coat of paint to stick and stay on the aluminum tank cannon barrel without gunking it up with thick primer etc. I have heard that Soaking in a mild acid like white vinegar is very useful. I'll open the thread for ideas!! Thanks!! I rarely post here but I hit this site every day!
DaneBramage aka Dane Bramage
Old 02-17-2011, 01:44 AM
Paul-H Paul-H is offline
A good quality Automotive primer should do the trick, mind I have vever had any bonding issues using model primer (I use Velejo), just make sure its clean and all maching and finger oils are removed.
If you still have problems then an etch type primer would help.
Paul
Old 02-17-2011, 08:46 AM
gordy gordy is offline
Founder
Out of curiosity, has anyone ever anodized an aluminum barrel ?
Old 02-17-2011, 10:37 AM
I used a gun bluing product on a RB FlaK 43 barrel just to see how it worked. Turned out great on both the Alum and Brass pieces. Then I tried it again on a Tamiya KwK 30 barrel (from their upgraded Sd.Kfz. 222) and it didn't turn out as well. I think I will continue to experiement though.
Old 02-17-2011, 12:10 PM
Good Luck in whatever choice you chose to paint the metal barrel.
Old 02-17-2011, 02:26 PM
Is that Tamiya metal primer any good?
Old 02-17-2011, 05:24 PM
ShotMagnet's Avatar
ShotMagnet ShotMagnet is offline
Has anyone tried Blacken-it?
Seemed to me that since it would work nicely as a basis for priming, but I've never tried it.
Shot
Old 02-17-2011, 08:31 PM
Pvt Mutt's Avatar
Pvt Mutt Pvt Mutt is offline
I tried it and no joy for me.
Tony lee
Old 02-18-2011, 10:29 PM
Holeshot's Avatar
Holeshot Holeshot is offline
For aluminum barrels, you need to get a can of "etchant primer" spray paint from a car parts store. It's specifically designed for priming aluminum parts. It has a chemical in it that etches the metal and creates a better mechanical bond between the paint and the metal than just paint alone would. You can paint over that just like any other primer.
Like Paul said, make sure all fingerprints and oils are removed from it; while you're at the car parts store pick up a can of "paint prep" too. You spray that on and wipe it off with a clean cloth and let it dry (it evaporates pretty quickly) and you should be good to go with the primer.
Good luck,
Curtis
Users like Holeshot's post!
Old 03-18-2011, 10:27 AM
I do a light sand on the barrel, seems to work the trick!
some others in my club have recommended krylon primers, but after i started doing the light sanding paint would stick fine.
For Sale Trump. 1/350 HMS Repulse / B&D metal gun barrels tamiyafan Market 0 04-22-2010 09:54 PM
For Sale Master models 1/350 16" metal barrels tamiyafan Market 0 04-11-2010 10:07 PM
Gun barrels T140 New Members, you must Post here first . Introduce yourself or just say hello. 10 01-06-2007 04:03 AM
metal replacements thanatza Scratchbuilding 4 12-28-2006 09:11 PM
Replacement barrels for Academy Lee? Uruk-Hai planetArmor General 0 10-30-2006 03:47 AM
