Old 11-10-2010, 10:39 PM
Fledermaus's Avatar
Fledermaus Fledermaus is offline
Schnellboot S-100
HI there!
Here is my next project, after doing the shinyo, I wanted to do another water based model to change from the always armor routine. This model has being waiting its turn and now is the moment. I have some aftermarket sets to go along with the model; it was bought in a bundle that included the azimuth 10 resin figure crew and the Bronco cloth flag. I added the Eduard’s gun PH set and the details PH set Also got the aluminum barrels for all the guns and the RB depth charge resin kit.
Here is the box with near to 40 inches long
And the extra stuff
So I began with the hull halves, it needs glue and also comes with screws for the bottom and 4 cross beams to make the hull rigid, it can be turned in to RC model.
A comparison with the box, it is a tight fit; the hull is as long as the box measuring 39 inches long
In this photos it appears to be longer than the box but it’s due to the lens angle. the figure near it
is an old 1/32 scale monogram figure so you can have an idea of the size of this beast
That’s for now, I’m moving to work in the guns first and then back to the boat itself, more soon
Thanks!
Abdin
"Don't be afraid of the model,it's you the one holding the knife"
Users like Fledermaus's post!
Old 11-11-2010, 09:07 AM
man, that's a lot of future painting you've got there...... but i like it. boats are always cool and especially one this size and in this scale. should be able to detail her up nicely. much cooler than a super small scale battleship IMO.
Old 11-11-2010, 03:08 PM
You're really into boating as I see! Good luck with this one, and great work on the other one!
Old 11-11-2010, 10:08 PM
That's a whole year of modeling ahead Din!
Ruben
Old 11-12-2010, 09:10 AM
Fledermaus's Avatar
Ruben, I will try not to drag my feet with this one
Old 11-12-2010, 11:37 PM
DaneBramage DaneBramage is offline
One Big Mother!!! Wow!! Looking forward to see your build!!
Old 11-13-2010, 12:32 PM
Fledermaus's Avatar
Chad I already have 5 bottles of model master grey paint waiting for it, also lots of PH = many hours of work
Hi Ropi, I wanted to take a breack from always armor, and this project sitting for about a year and now is its turn
thanks Dane, it really is big and thats what I like the most of it
Old 11-13-2010, 01:16 PM
WillysJeep's Avatar
WillysJeep WillysJeep is offline
Wow, its huge!
Looking forward to seeing it enhanced with those aftermarket products.
Tim
Old 11-14-2010, 02:59 PM
Fledermaus's Avatar
thanks Tim, I have a lot of metal work ahead, hope it will end as I have planned
Abdin
Old 11-20-2010, 03:00 PM
Fledermaus's Avatar
Hi to all, Work on the model continues with the guns. First the twin 20mm, it received the Eduard details and shield
First the gun details are removed to be replaced by the PE ones; also the barrels are cut and drilled to allow for the aluminum ones
The new shield with all the parts installed
A comparison with the original one, a great improvement, the same with the ammo rack
Some of the installed PE parts, the gun sight is nicely detailed an a bitch to assemble
So the solder gun saw lots of action
A dry test of the shield
At this stage I realized that the 20mm barrels I have are shorter by about 5/16 than the needed ones, so I have to wait for the new ones to arrive…that’s for now and thanks for watching
Abdin
