Old 12-12-2012, 03:38 AM
Eddy Eddy is offline
8.8cm FlaK 18 Selbstfahrlafette
A few months agoo I started with the 88 FLAk 18 selbstfahrlafette from Trumpeter. After reading some reviews I though it should be a peace of cake, right out the box, but when I did some research and compared it with photo's of the real thing I found that there was a lot to change.
first of all, Trumpeter made curved side plates of the drivers housing while they should be straight.
They also forgot the triangle reinforcements on the front of them.
Further, all the plates they used are to thick and when you make them thinner they are to small, so the side plates of the motor compartment where made larger and the hood was made of copper
The main gun in the box is a beauty but with to much detail; The 88 on the real thing was actually a PAK that means that all the devices of the FLAK gun were removed and only the direct visor was kept, also instead of 1 hand wheel there were 2 on the same station. The main adaption was on the recuperator on top of the gun tube, this was reinforced and a bullet splash guard was added
The ammo cannister attached on the gun shield is to big and in a wrong angle so I made a new one
There was a choice for the gun shield, one in plastic and a beauty in photo etch, but in comparison with the rest of the plating this one is to thin in my opinion, so I used the plastic one but thinned down the main shield and made new ones for the side
Before putting it all together The inside of the drivers housing was painted
That's it for now, later the painting stage on which I am busy.
Eddy
The Following 3 Users Say Thank You to Eddy For This Useful Post:
Old 12-12-2012, 06:49 AM
this vehicle reminds me of old mob cars
great progress
Users like KuKŁiNsKi's post!
Old 12-13-2012, 03:47 AM
This vehicle was used in the early war years, the last of them served in Russia. I choose the cammo of the may 1940 period, grey and brown and a yellow air recognition flag on the hood made of Duro.
Here is the grey base
The gun in 2color, I use an old 88mm base for easy panting
Weathering
The drivers housing is finished, see the difference between the weathered and the non weathered part.
Now I start with the motor compartment,
Thanks for looking
Eddy
The Following 2 Users Say Thank You to Eddy For This Useful Post:
Old 12-13-2012, 11:15 AM
looking good =)
Old 12-14-2012, 03:13 AM
looks great so far!
any plans for figures or dio?
Old 12-15-2012, 09:37 PM
mike walsh's Avatar
mike walsh mike walsh is offline
This is very nice.
I like the colour shading and weathering.
Good detail work.
Old 12-17-2012, 04:09 PM
tankette
Thanks guys for your comment
Now the hood and one of the motor compartment plates are almost, some minor details had to be done when this paint is dry
Eddy
Old 12-17-2012, 07:03 PM
T90's Avatar
T90 T90 is offline
Looks great Eddy....
Old 12-21-2012, 05:54 AM
Thanks T90.
One side is finally finished
Thanks for looking
Eddy
ID:	7217   Click image for larger version
Users like Eddy's post!
Old 12-30-2012, 10:00 AM
The vehicle almost reaches the final stage, the front is done, now the front wheels and then I can start with the 88mm
2cm Flakvierling 38 auf Selbstfahrlafette Sd.Kfz.7/1 panzerjager Photos: In-progress Blogs 49 07-08-2010 11:47 PM
Dragon Sd.Kfz. 7/1 2cm Flakvieling 38 auf Selbstfahrlafette James Tainton Photos: In-progress Blogs 25 07-28-2009 05:37 PM
12.8cm Selbstfahrlafette L/61 ''Sturer Emil'' Panzergrenadier Photos: In-progress Blogs 9 05-20-2006 05:26 AM
12.8 cm Selbstfahrlafette L/61 James Tainton Photos: In-progress Blogs 8 10-04-2005 04:03 AM
DML 88mm Flak 36/Flak Artillery Crew Flak planetArmor General 10 06-01-2005 03:05 PM
