Old 08-26-2007, 01:59 PM
Warped Resin
Many times a kit which has been stored will become warped. Whether at the stockist or in your stash, pressure or temperature may cause thin long items to warp.
Here are some thin resin Panzer 38 (t) sprockets that were deformed during shipment. The inset shows them after a dip.
The technique is simple and based on the principle that resin has memory. If the manufacturer allowed the resin to fully cure in a true and level mold, the resin will return to the shape it had in the mold if given the opportunity.
I usually boil water and put it into a clear container so I can see the effect of the heat. Here I am using a Pyrex measuring cup as my normal coffee press jar is too unsightly ;-)
Note that one must hold the item by the carrier sprue. In the case above, this was not a good idea as the warmed up resin sprocket began to deform from the weight of the water. I had to hold one of the fins between the sprockets and re dip it.
The idea is to dip the item into the water slowly and watch it relax into the proper shape. This means that the item can not touch any of the sides or bottom.
After the proper shape if regained, slowly remove the item from the hot water and dip into cold water. After it is in the cold water, it can be placed onto a towel to air dry.
Here we have Tank Work Shop's British Style Wading Kit as it came out of the package. I did NOT remove the casting blocks and used them as a handle to dip them into the hot water.
Post dip, note the water droplets still on it:
This has worked on EVERY warped item I have except for an Eastern European one which I suspect was warped in the mold. I have straightened out items as delicate as the above to thicker hulls (which warped under pressure).
The bottom line is to NOT touch, push, prod, the piece and allow it to regain the original shape on its own. Believe me, it's memory is a lot better than you can do when it comes to straightening out gun barrels!
I hope this quick tip is of help.
Saúl García
Yesterday is History
Tomorrow is a Mystery
Today is a Gift
It is why it is called The Present!
Old 08-27-2007, 08:10 AM
MrJody MrJody is offline
Great tip Saul. Thanks for taking the time to post it.
Jody.
Old 08-27-2007, 09:18 AM
Awesome tip Saul
Old 08-27-2007, 07:01 PM
Thank you for the nice little instruction!
Old 08-27-2007, 07:23 PM
"It's a good thing"
thanks Saul
Old 08-27-2007, 09:45 PM
Well, while trying to keep up with the Joneses , I will create a small video of my repair on this bad boy...
Left in a box in the trunk during VERY hot days!
I've cleaned my decrepit coffee carafe so all I need to do is boil the water and let the camera do its magic!
Should I post the link here if successful?
Saúl García
Today is a Gift
Old 08-28-2007, 05:00 AM
Primus's Avatar
Primus Primus is offline
Absolutely! Post the link
Old 08-28-2007, 12:25 PM
Yes please do, it will be fun!
Old 08-28-2007, 01:13 PM
NAS's Avatar
NAS NAS is offline
Hello Saul,
thanks a lot for this very usefull tip!
Can't wait to see the video!
Notger
WIP:
DML Pz IV G April-May 1943
DML Neubau-Fahrzeug Nr. 2
DML Jagdpanzer IV L/70(A)
Historyfacts
Pz.Kpfw. IV
Old 08-29-2007, 12:26 AM
So??????????
1/35 Resin Figures dan_roh Market 0 08-18-2007 04:04 AM
Resin and Plastic sale Sean Dunnage Market 1 08-05-2007 07:51 PM
Warped Tristar PZIA lower hull? panamadan planetArmor General 5 02-25-2007 09:25 AM
New to Resin Mike McGregor planetArmor General 2 09-06-2005 10:55 PM
prime resin before painting tazz Allied: World War II 3 03-23-2004 02:46 PM
