This is a resin base I picked up from my LHS. Its pretty simple but I felt it could be made to shine, with a little work done on it. Obviously this'll be a dry autumn scene, with leaves.
I've added a resin tree stump, cemented in place with superglue. For the groundwork around it I used Vallejo Coarse Pumice to make it look like it grew there (no pun intended). Around this and over the base i've added some static grass, cemented in place with watered down wood glue. The grass was then airbrushed, and toned down a little.
With a Dremel, I drilled out some of the base to form some broken earth. Next up will be to add some more gravel effects, which I feel this needs now! Then a small amount of some PlusModel autumn Oak and Linden leaves'll be added.
