Old 11-05-2012, 10:04 PM
Jagdtiger Porsche Production - Dragon
Hello fellow modelers and dear friends.
Itís been forever since Iíve posted any new work. But finally itís time to get into the grind again. Here is a build I did some time back. Its Dragonís Jagdtiger Porsche Production Type.
Stared working with the suspension. That is usually the most tedious part of the build, however this one went together very well.
Once that was done I moved to assemble the hull. I used the plastic rod + liquid cement technique to simulate weld lines along the hull plates in the rear of the tank.
The next thing to address was the plates of the armor. These were cut very roughly on the real vehicles and I wanted to replicate this in 1/35. I used a triangular file to create the texture.
I also added the small brackets that held the jack in place using plastic rod. I added a plastic wing nut from Bronco at the top of each rod.
Also the exhausts and the tools on the rear plate.
The Lower hull is coming alongÖ
Until next time..
The Following 2 Users Say Thank You to David Diaz For This Useful Post:
Old 11-06-2012, 12:25 AM
Looking good so far!
Old 11-06-2012, 03:04 AM
ParanoAndroid ParanoAndroid is offline
Great job Dave ! I can't wait to see more of it!
Alex!
Old 11-06-2012, 03:16 AM
Grim' Grim' is offline
Great, a Jagdtiger ! Nice work so far on the hull !
Old 11-06-2012, 10:25 PM
Thanks Guys!
Old 11-06-2012, 10:45 PM
Thanks Guys!
Here is another update.
Using Mr Surfacer I added texture to the exhaust covers.
I started working on the upper hull. I decided to scratch built the brackets and the barrel rods. I used plastic styrene for this.
Added welding lines to the brackets.
The rods in place.
I completed the brackets and added Bronco wing nuts to them.
Thanks for followingÖ
Old 11-07-2012, 05:14 AM
I'm impressed by your accuracy!
Looking forward to seeing more of it!
Old 11-07-2012, 11:29 AM
m1garand's Avatar
m1garand m1garand is offline
Nice work!
Very accuracy.
The other consoles will be welding line?
Jagdtiger Walk Around
Sanyi
Visit my blog:
www.makett.tk
Old 11-07-2012, 08:23 PM
Thanks for the replies guys.
You mean if I am going to add weld lines to the rest of the brackets?
Old 11-08-2012, 01:09 PM
m1garand's Avatar
Yes. : )
Sanyi
Visit my blog:
www.makett.tk
King Tiger Porsche Panzerkompanie 316 Dragon 1:35 Open uki761 Photos: In-progress Blogs 8 12-10-2012 09:14 PM
Jagdtiger porsche production oishi Photos: In-progress Blogs 12 02-21-2012 02:39 PM
DML Porsche Jagdtiger Part 2 Pvt Mutt Photos: In-progress Blogs 46 08-05-2008 08:51 AM
DML Porsche Jagdtiger Pvt Mutt Photos: In-progress Blogs 72 06-14-2008 06:24 AM
Jagdtiger Late Production. kiwi45 Photos: In-progress Blogs 5 11-08-2005 07:22 PM
