Go Back   planetArmor > planetArmor Features > Group Builds > Past Group Builds > Sturmgeschuetz Group Build (closed)
Sturmgeschuetz Group Build (closed) StuG III Ausf.G DML Smart Kit - PA Group Build
Closed Thread
Old 04-13-2008, 11:30 AM
Sturmi Marjatta WIP.
Hello Fellows!
Heres my Sturmi in progress but I have a few questions that I hope your Finnish friends could help me with.
1. Should this box be removed when Im adding the new storage box?
2. Were both antennas used on this vehicle and was it the longer german type?
3. Did the Finns have sparetracks here as the Germans had?
4. Should I add a bit of tarp here as protective?
5. I could really use a picture of the DT machine gun mount especially with the gun mounted? And were the shell catching bag attached in combat?
6. I dont think I understand how the cupola is supposed to be, even after reading the post here:
http://www.andreaslarka.net/phpBB2/viewtopic.php?t=67
I understand that the scissorscope should be attached to the upper flat ring. But what did the mount look like and how should the hatch be positioned?
top
Old 04-16-2008, 01:32 AM
Bumping my own post.
Please Mikko or Andreas, help me out to finnish this project, pardon the pun?
top
Old 04-16-2008, 05:37 AM
Andreas Larka Andreas Larka is offline
1) Yes
2) Yes. Is there a shorter "Finnish type" available?
3) Yes.
4) No. The early ones had the bigger tarp covering the front part of the roof. It had a hole for the gun.
5) The stand is quite simple. Just a piece of metal with a hole in it. I don't think that the bag was attached in combat.
6) The scissorscope should be located behind the plated over periscope and the hatch hinges should be on the opposite side. Judging from your picture, just flip the upper ring 180 degrees.
Andreas Lärka
Vantaa, Finland
Webmaster for http://www.andreaslarka.net
(Überbesserwisser and official StuG-police!)
top
Old 04-16-2008, 05:56 AM
Thanks, Andreas! That helped very much.
Is there any pictures of the earlier type or is it of the same type the Germans used?
When it comes to the cupola. I dont think I still dont understand. Left in the picture Ive posted is the front of the Sturmi. Should the "blind" spot of the cupola be facing forward and have the scissor scope?
Ive actually also thought of building Marjatta after the conversions as well.
top
Old 04-16-2008, 06:18 AM
Janne
The following photo on Andreas' site should help
http://www.andreaslarka.net/ps531042/2007_53104214.jpg
top
Old 04-16-2008, 10:41 AM
COOL project you have going on there.
top
Old 04-16-2008, 02:01 PM
AfRiKaKoRpS's Avatar
AfRiKaKoRpS AfRiKaKoRpS is offline
Send a message via Skype™ to AfRiKaKoRpS
Cool work Janne and good to see your project close to "finish" .
Chris
StuG III Ausf.G DML Smart Kit - Dec 1942 Production Initial StuG III G - Russia 1942/43 - PA Group Build
StuG IV DML Smart Kit - 2. Kompanie Panzerjäger-Abteilung Brandenburg /1. Jäger-Rgt. "Brandenburg" - Poland 1945
top
Old 04-17-2008, 03:22 AM
Yes.
And the same in Swedish: Om man tänker sig att kupolen är vänd rakt framåt (den är ju 360 grader vridbar) så skall den igensvetsade biten vara vänd framåt, och kikaren skall sticka upp bakom den. Givetvis så måste då luckan vara fastsatt mitt emot, dvs. vid det bakre periskopet / prismat.
Dragon har gjort sin modell efter en senare, icke vridbar, årsmodell. Där var den igensvetsade biten bak och periskopet / prismat fram. Och naturligtvis kikaren där fram. Detta är dock fel för dessa tidigare årsmodeller.
Andreas Lärka
Vantaa, Finland
top
Old 04-17-2008, 10:25 AM
Mark S. Pryor's Avatar
Mark S. Pryor Mark S. Pryor is offline
Janne
This is also from Andreas' site.
http://www.andreaslarka.net/ps531008/2003_53100807.jpg
Hope it helps. It is from #531-8 'Aili"
Also.
http://www.andreaslarka.net/ps531010/2004_53101019.jpg
labled rotating commander's cupola.
http://www.andreaslarka.net/ps531011/2007_53101114.jpg
http://www.andreaslarka.net/ps531026/53102619.jpg
Mark
Weirld Al in "UHF" Badgers! Badgers! We dont need no stinking Badgers!
top
Old 04-17-2008, 01:47 PM
Thanks everybody!
Now everything is cleat or at least I think so.
top
Closed Thread
Sturmi MikkoH Sturmgeschuetz Group Build (closed) 44 03-15-2008 02:59 AM
