Old 03-08-2008, 03:04 PM
kinfa-t's Avatar
kinfa-t kinfa-t is offline
Mud
How to make mud?
Does enybody have any idea?
Please help!
I heard that you can use coffee, woodfix mixed with pastels?
BOG I HRVATI!
Old 03-08-2008, 03:13 PM
Originally Posted by kinfa-t View Post
How to make mud?
Please help!
Depends on where the mud is going to be applied,(on the model or on the ground). Maybe be more specific.
There are dozens of different ways-
How about
mix up some fine powdered dirt and diluted white glue into a thick paste and dabbed it on the frame and tires to represent dried mud.
or...
http://www.diorama.pl/workbench_mud.html
Old 03-08-2008, 05:34 PM
Try this:
http://www.tankbuilder.net/howto/MUD/howto.htm
Old 03-08-2008, 06:18 PM
kinfa-t's Avatar
well, i am going to applied it on Leningradec T-34/76 winter scheme, so it will be on whe wheels, tracks and on the lower hull.
BOG I HRVATI!
Old 03-08-2008, 06:20 PM
kinfa-t's Avatar
what is Plaster of Paris
BOG I HRVATI!
Old 03-08-2008, 07:37 PM
Just Plaster - I prefer Dental Stone cause it has greater compressive strength, but any hardware store will have regular plaster.
Old 03-08-2008, 07:47 PM
Plus it's probably a write off?
Probably lots of cool things from your work world that can be used in the hobby?
Old 03-08-2008, 08:15 PM
Yeah James there really is alot of good things that can serve double duty - including the camera!
Old 03-09-2008, 12:45 PM
james84's Avatar
james84 james84 is offline
I've seen on many magazines that they make mud with pigments+paint in different amounts+plaster or sand in different grains. Sometimes they also use Mig's acrylic resin. You can achieve a mud effect simply with flat paint+ pigments for dry mud or gloss paint+pigments for fresh mud, keeping in mind that the latter is darker and that a pigment mixed to clear paint gives you a darker tone. The trick is not to make a homogeneous mix though!
Old 03-09-2008, 01:44 PM
Bruga Bruga is offline
"Gips"
I use the Molto brand with good results.
You can use acryllic gel used for oil paintings to achieve a more "humid" looking-mud (Then you have to use more gel than plaster and pigments to colour the mix)
Antonio
