Old 11-27-2007, 09:29 PM
Painting Oxidized Bronze
Hello everyone!
Since I was asked on the colors used to paint the bronze plaques on the T-34 base I decided to make a short SBS on how I did it.
First I want to point that this is only one of the many approaches that can be used to make this effect. I have found this technique easy to use and the results quite convincing. My best suggestion is to go ahead and experiment until you find a technique you are comfortable with.
Here is the list of the colors needed. They are all acrylics.
From Vallejo acrylics:
1.Tinny Tin
2.Brassy Brass
3.Bright Bronze
4.Bronze Green
5.German Fieldgrey WWII
6.Turquoise Glaze (from Citadel Color)
I will be using this fantasy warrior’s shield to demonstrate the technique.
I applied a coat of Flat Black primer.
Next I applied drybrushing using Tinny Tin. Make sure you cover a lot of the raised surfaces with this first drybrush.
Once dry I applied a wash using Bronze Green. This will represent the characteristic green patina that forms on bronze when it oxidizes.
Once the wash is dry a second drybrush is applied, this one with Brassy Brass. This coat is lighter than the first drybrush.
Next is a second wash. This time using German Fieldgrey.
Once dry the final drybrush was made using Bright Bronze and making sure you pick all the raised areas.
Finally I applied a thin coat of Turquoise glaze over the piece.
There you have it, oxidize bronze.
Old 11-27-2007, 09:49 PM
Awesome technique David!
Old 11-28-2007, 12:31 AM
Totally Sick DAVID!!!!
Laz
Old 11-28-2007, 08:44 AM
nicely done!
Saúl García
Yesterday is History
Tomorrow is a Mystery
Today is a Gift
It is why it is called The Present!
Old 11-28-2007, 10:59 AM
Super Thanks!
Old 11-28-2007, 02:39 PM
the FORCE is strong with this one...
thanks Dave,
Old 11-28-2007, 03:04 PM
A big pat on the back for you Dave!
Old 11-28-2007, 09:12 PM
Cool...Dave
Painting tools... Tigermud Painting & Weathering 2 11-03-2007 07:16 PM
Painting or Building? Panzergrenadier planetArmor General 6 08-31-2007 05:17 PM
Painting Bases - 1 brokeneagle Painting & Weathering 18 06-16-2006 05:45 AM
Painting Tracks armorstu Painting & Weathering 8 06-14-2006 08:49 AM
prime resin before painting tazz Allied: World War II 3 03-23-2004 02:46 PM
