Old 11-22-2007, 05:17 AM
Primus's Avatar
Primus Primus is offline
Question Russian green
I'm using Vallejo model color for airbrushing my models. I'm into German armor so I'm a little lost, which mix do you use for Russian green?
Thanks in advance!
Old 11-22-2007, 07:56 AM
sbuss sbuss is offline
why don't you just use "russian green", as this is already mixed and readily available from Vallejo?
Stefan
Old 11-22-2007, 09:06 AM
Primus's Avatar
I think that V. russian green is a little too dark.
Old 12-05-2007, 10:08 AM
Blackout's Avatar
Blackout Blackout is offline
Add a little of vallejo german camo light green bit by bit, this will makes it a bit more lighter and lively. That is what i do with my russian tanks.
Old 01-05-2008, 11:28 AM
Cadu Souza's Avatar
Cadu Souza Cadu Souza is offline
Primoz,
You are right, the color is a little dark and will make the weathering job a madness.
This is my KV2 painted with Vallejo's Model Air pure RUSSIAN GREEN .
As mentioned, i decided to lighten the color a little and the result is a lot better.
Best Regards,
Cadu Souza
'Cause we hunt you down without mercy
Hunt you down all nightmare long
Feel us breathe upon your face
Feel us shift, every move we trace
Hunt you down without mercy
Luck. Runs!
Old 01-05-2008, 06:39 PM
Primus's Avatar
Thank you for your input Carlos; which color did you use for lightening?
Old 01-18-2008, 09:52 PM
Thanks in advance!
Primoz,
another suggestion is to not think so 1 dimensionally about a color (I mean this in a helping way). I always feel the standard base color for any particular vehicle can be veiwed as midway in a scale that runs from the darkest as a base for shading to the lighest as a worn and sun-faded version. When you airbrush the layers you either bring to half way or continue depending on the fade. You would use the darker color for simulating a wet tank. Doing a Russian green would involve4-6 layers depending on how used you want the paint. You will also find this gives you more realism. So you see, if the color provided is right then you only need to work with the tint to lighten it. Any color is made up of many layers.
Vallejo will work
I hope this helps.
Old 01-18-2008, 11:00 PM
Primoz, there is no such colour as "Russian Green", or at least no Soviet colour.
There was a specification calling for a colour known as 4BO Protective Green to be used as the base colour for Soviet armour. There were several versions of the collour over the course of the war, and another version (same name) used for aircraft. You can get an idea of the variations by looking at many of the preserved tanks in Russia.
Bottom line: find a nice medium-dark green, one that pleases you, and go with it. The shade on Cadu's KV works for me, but so do others. You decide.
The green mile - s.SS 501 Pz.Abt Tiger II 213 panzerjager Photos: In-progress Blogs 105 07-22-2007 06:38 PM
Review of the new Etch mate 3C by Brett Green holmerz Your important news and kit reviews. 0 01-06-2007 02:13 AM
Squadron Green & White Putty Question lquah Painting & Weathering 5 12-31-2006 04:30 PM
Russian hut Frederik Felder Photos: In-progress Blogs 7 08-26-2006 01:21 AM
Paint suggestions for WWII USMC Green? Havoc Allied: World War II 2 05-19-2005 04:38 PM
